Aller au contenu principal
Dell Inspiron 14 3465 Base Cover Replacement
darrius
darrius et un autre contributeur
Dernière mise à jour le November 9, 2019
15 - 20 minutes
Très facile
Tutoriel réalisé par la communauté
How To Remove And Replace The Base Cover
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 14 3465 Base Cover Replacement, Turning The Computer Over: étape 1, image 1 de 1
    • Close the display, and turn the computer over.
  2. Dell Inspiron 14 3465 Base Cover Replacement, Removing Eight Screws: étape 2, image 1 de 1
    • Remove the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3465 Base Cover Replacement, Removing Two Screws: étape 3, image 1 de 1
    • Remove the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3465 Base Cover Replacement, Rmoving Three Screws: étape 4, image 1 de 1
    • Remove the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3465 Base Cover Replacement, Open The Display: étape 5, image 1 de 1
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3465 Base Cover Replacement, Removing Three Screws: étape 6, image 1 de 1
    • Remove the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  7. Dell Inspiron 14 3465 Base Cover Replacement, Disconneting The Optical-Drive Cable: étape 7, image 1 de 1
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3465 Base Cover Replacement, Turn Over The Computer: étape 8, image 1 de 1
  9. Dell Inspiron 14 3465 Base Cover Replacement, Prying The Base Cover: étape 9, image 1 de 1
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3465 Base Cover Replacement, Lifting The Base Cover: étape 10, image 1 de 1
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3465 Base Cover Replacement, Releasing the optical-drive: étape 11, image 1 de 1
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3465 Base Cover Replacement, Sliding the optical-drive: étape 12, image 1 de 1
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3465 Base Cover Replacement, Placing The New Base Cover: étape 13, image 1 de 1
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3465 Base Cover Replacement, Sliding The Tabs: étape 14, image 1 de 1
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3465 Base Cover Replacement, Sliding The Optical-Drive Cable: étape 15, image 1 de 1
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Three Screws: étape 16, image 1 de 1
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3465 Base Cover Replacement, Turn Over The Computer: étape 17, image 1 de 1
  18. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Three Screws: étape 18, image 1 de 1
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Two Screws: étape 19, image 1 de 1
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Eight Screws: étape 20, image 1 de 1
    • Replace the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly
darrius
Membre depuis le 03/26/18
5 213 Réputation
30 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 181
