Aller au contenu principal
Dell Inspiron 14 M4010 Hard Drive Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 6, 2019
8 - 25 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron 14 M4010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: étape 2, image 1 de 1
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 5, image 1 de 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 M4010 Hard Drive Replacement, Align the Screws: étape 6, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron 14 M4010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: étape 7, image 1 de 1
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron 14 M4010 Hard Drive Replacement, Replace the Screws: étape 8, image 1 de 1
    • Replace the two screws that secure the hard-drive assembly to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 76
