Aller au contenu principal
Dell Inspiron 14 N4020 Hard Drive Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 14, 2019
2 - 15 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace the Hard Drive.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 14 N4020 Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 N4020 Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 2, image 1 de 1
    • Slide the hard-drive assembly out of the hard-drive compartment.
  3. Dell Inspiron 14 N4020 Hard Drive Replacement, Remove the Screws: étape 3, image 1 de 1
    • Remove the two screws that secure the hard-drive bezel to the hard drive.
  4. Dell Inspiron 14 N4020 Hard Drive Replacement, Removing the Hard Drive Bezel: étape 4, image 1 de 1
    • Pull the hard-drive bezel away from the hard drive.
  5. Dell Inspiron 14 N4020 Hard Drive Replacement, Align the Screw Holes: étape 5, image 1 de 1
    • Align the screw holes on the hard-drive bezel with the screw holes on the NEW hard drive and replace the two screws.
  6. Dell Inspiron 14 N4020 Hard Drive Replacement, Sliding the Hard Drive Assembly: étape 6, image 1 de 1
    • Slide the hard-drive assembly into the hard-drive compartment until it is fully seated.
  7. Dell Inspiron 14 N4020 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 8
Total : 454
