Dell Inspiron 14-5415 Battery Replacement
Introduction
Passez à l'étape 1This guide will teach you how to properly replace your battery in a Dell Inspiron 14-5415.
The battery is a hardware component that helps regulate the power supply to the laptop, allowing it to function without a power cord or access to mains power. A faulty battery can lead to unexpected shutdowns, reduction of battery life, overheating, charging difficulties, and potential safety hazards.
Before you continue with this guide, make sure to check out our troubleshooting page. A glitch in your laptop might be misinterpreted as a malfunctioning battery, and will not require replacement.
If your device is experiencing symptoms that have not been stated in our troubleshooting page, here are some useful links that you can use to identify the condition of your device.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Remove the five 3 mm screws that secure the battery to the palm-rest and keyboard assembly using a Phillips #00 screwdriver.
To reassemble your device, follow these steps in reverse order.
