Aller au contenu principal
Dell Inspiron 14-5447 Fan Replacement
Isabella Chavez
Isabella Chavez et 8 autres contributeurs
Dernière mise à jour le May 7, 2024
10 minutes
Modérée
This guide will teach users how to replace a faulty fan for the Dell Inspiron 14-5447. With removal of the fan, cleaning any debris left behind will help your new fan run much quieter and have better cooling circulation.
Prior to beginning this repair, be sure to power off the laptop and unplug it from the power cord.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell Inspiron 14-5447 Fan Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Fan Replacement: étape 2, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 2, image 2 de 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Fan Replacement: étape 3, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 3, image 2 de 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Fan Replacement: étape 4, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 4, image 2 de 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Fan Replacement, Fan: étape 5, image 1 de 1
    • Locate the fan system in the top right corner.
  6. Dell Inspiron 14-5447 Fan Replacement: étape 6, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 6, image 2 de 2
    • Look along the wide line of white cable until you find the tab insert.
    • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
  7. Dell Inspiron 14-5447 Fan Replacement: étape 7, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 7, image 2 de 2
    • Move the cable over to the side to reveal the fan screws.
    • Remove the two black 5.70 mm screws from the fan.
  8. Dell Inspiron 14-5447 Fan Replacement: étape 8, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to remove the small cable attached to the fan.
  9. Dell Inspiron 14-5447 Fan Replacement: étape 9, image 1 de 2 Dell Inspiron 14-5447 Fan Replacement: étape 9, image 2 de 2
    • Using the opening tool, pry the fan out.
    • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
  10. Dell Inspiron 14-5447 Fan Replacement: étape 10, image 1 de 1
    • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
Isabella Chavez
Membre depuis le 04/11/17
476 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 16
Total : 878
