Aller au contenu principal
Dell Inspiron 14-7437 Speaker Replacement
Katelyn Remy
Katelyn Remy et 3 autres contributeurs
Dernière mise à jour le August 8, 2019
6 minutes
Facile
if the speaker is not playing sounds properly or liquid is spilled into the speaker gap in the frame of your laptop it is easy and simple to replace them.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 14-7437 Speaker Replacement, Base Cover: étape 1, image 1 de 2 Dell Inspiron 14-7437 Speaker Replacement, Base Cover: étape 1, image 2 de 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Speaker Replacement: étape 2, image 1 de 2 Dell Inspiron 14-7437 Speaker Replacement: étape 2, image 2 de 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Speaker Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 14-7437 Speaker Replacement, Battery: étape 3, image 2 de 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Speaker Replacement: étape 4, image 1 de 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Speaker Replacement: étape 5, image 1 de 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Speaker Replacement, Speaker: étape 6, image 1 de 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Speaker Replacement: étape 7, image 1 de 3 Dell Inspiron 14-7437 Speaker Replacement: étape 7, image 2 de 3 Dell Inspiron 14-7437 Speaker Replacement: étape 7, image 3 de 3
    • Remove the speakers from the case.
Katelyn Remy
Membre depuis le 03/10/16
449 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-8, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 17
Total : 1,121
