Aller au contenu principal
Dell Inspiron 1440 Speaker Replacement
Tyler Lyons
Tyler Lyons et 4 autres contributeurs
Dernière mise à jour le January 6, 2020
5 - 15 minutes
Modérée
Removing and replacing the Dell Inspiron 1440 speakers is a slightly difficult process because it involves going inside of the computer. Once the screws are out of the speaker, it can be tricky to get them out, so use caution when doing this step. The tools needed to do this are a screwdriver and a prying tool.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 1440 Speaker Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 1440 Speaker Replacement, Keyboard: étape 1, image 2 de 2
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 Speaker Replacement: étape 2, image 1 de 1
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 Speaker Replacement: étape 3, image 1 de 1
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 Speaker Replacement, Speaker: étape 4, image 1 de 2 Dell Inspiron 1440 Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that are surrounding and underneath the middle plate.
  5. Dell Inspiron 1440 Speaker Replacement: étape 5, image 1 de 2 Dell Inspiron 1440 Speaker Replacement: étape 5, image 2 de 2
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 Speaker Replacement: étape 6, image 1 de 2 Dell Inspiron 1440 Speaker Replacement: étape 6, image 2 de 2
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 Speaker Replacement: étape 7, image 1 de 3 Dell Inspiron 1440 Speaker Replacement: étape 7, image 2 de 3 Dell Inspiron 1440 Speaker Replacement: étape 7, image 3 de 3
    • Remove the 4 mm screws on either end of each speaker. Once they are removed, pull up the speaker.
Tyler Lyons
Membre depuis le 11/05/19
452 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, Barthe Fall 2019
UMASSD-BARTHE-F19S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 19
Total : 421
