Aller au contenu principal
Dell Inspiron 14z-5423 Hard Drive Replacement
Brittany
Brittany et 3 autres contributeurs
Dernière mise à jour le January 22, 2020
20 minutes
Modérée
The hard drive is the main storage for the computer which includes the opperating system, files, photos, and videos. This is often replaced when the drive becomes full.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Dell Inspiron 14z-5423 Hard Drive Replacement, RAM: étape 1, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, RAM: étape 1, image 2 de 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 2, image 1 de 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 3, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 3, image 2 de 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 4, image 2 de 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 5, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 5, image 2 de 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Hard Drive Replacement, Optical Drive: étape 6, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, Optical Drive: étape 6, image 2 de 2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Hard Drive Replacement, Keyboard: étape 7, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement, Keyboard: étape 7, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement, Keyboard: étape 7, image 3 de 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 8, image 1 de 1
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 9, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 9, image 2 de 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 10, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 10, image 2 de 2
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 11, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 11, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 11, image 3 de 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Hard Drive Replacement, Palm Rest Assembly: étape 12, image 1 de 1
  13. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 13, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 13, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 13, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 14, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 14, image 2 de 2
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 15, image 1 de 1
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 16, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 16, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 16, image 3 de 3
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Hard Drive Replacement, Battery: étape 17, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, Battery: étape 17, image 2 de 2
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 18, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 18, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 18, image 3 de 3
    • Lift the tiny black tab and pull the battery out at a slight angle.
  19. Dell Inspiron 14z-5423 Hard Drive Replacement, Hard Drive: étape 19, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, Hard Drive: étape 19, image 2 de 2
    • Lift up the bottom of the hard drive which is located at the bottom of the laptop.
    • Gently pull the drive out at an angle using your fingers.
  20. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 20, image 1 de 1
    • Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
  21. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 21, image 1 de 1
    • Slide the hard drive out of the bracket.
16 autres ont terminé cette réparation.
Brittany
Membre depuis le 09/12/16
917 Réputation
4 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-2, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 membres
11 tutoriels rédigés
5 commentaires
Worked perfectly, right down to the last screw under the memory.
Michael Maxson - Réponse
You are a lifesaver! Thank you.
hiddenpcmaster - Réponse
Thanks! These instructions worked very well for me, and I performed my battery and disk upgrades successfully!
ericfogleman - Réponse
This guide was straight forward and gave me the exact step by step instructions! Good job!
Arun Venkiteswaran - Réponse
Even a dumbass as myself would understand this and follow through. Thank you author!!!
Fon Nguti Abraham - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 29
Total : 6,704
