Aller au contenu principal
Dell Inspiron 15 3568 Display Assembly Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 23, 2019
3 - 7 minutes
Modérée
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: étape 1, image 1 de 1
  2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: étape 2, image 1 de 1
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: étape 3, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: étape 5, image 1 de 1
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: étape 6, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: étape 8, image 1 de 1
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: étape 9, image 1 de 1
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 625
