Dell Inspiron 15 5565 Display Assembly Replacement
Introduction
Passez à l'étape 1In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
Note the display cable routing and remove the cable from its routing guides.
Lift the latch and disconnect the display cable from the system board.
Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
Lift the palm rest and keyboard assembly off the display assembly.
Place the palm rest and keyboard assembly on the NEW display assembly.
Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
Route the display cable through the routing guides on the palm rest and keyboard.
Slide the display cable to the connector on the system board and close the latch to secure the cable.
Slide the battery cable to the connector on the system board.
