Aller au contenu principal
Dell Inspiron 15 5566 Display Assembly Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 23, 2019
8 - 25 minutes
Modérée
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 15 5566 Display Assembly Replacement, Note the Antenna Cable: étape 1, image 1 de 1
  2. Dell Inspiron 15 5566 Display Assembly Replacement, Lifting the Latch: étape 2, image 1 de 2 Dell Inspiron 15 5566 Display Assembly Replacement, Lifting the Latch: étape 2, image 2 de 2
    • Lift the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15 5566 Display Assembly Replacement, Note the Display Cable: étape 3, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guides.
  4. Dell Inspiron 15 5566 Display Assembly Replacement, Open the Display: étape 4, image 1 de 1
    • Turn the computer over.
    • Open the display at an angle of 90 degrees.
  5. Dell Inspiron 15 5566 Display Assembly Replacement, Placing the Display: étape 5, image 1 de 1
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  6. Dell Inspiron 15 5566 Display Assembly Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the four screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  7. Dell Inspiron 15 5566 Display Assembly Replacement, Lifting the Display Assembly: étape 7, image 1 de 1
    • Lift the display assembly off the palm-rest assembly.
  8. Dell Inspiron 15 5566 Display Assembly Replacement, Placing the Palm Rest: étape 8, image 1 de 1
    • Place the palm-rest assembly at the edge of the table with the coin-cell battery facing away from the edge.
  9. Dell Inspiron 15 5566 Display Assembly Replacement, Align the Screw Holes: étape 9, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 15 5566 Display Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
    • Close the display and turn the computer over.
  11. Dell Inspiron 15 5566 Display Assembly Replacement, Routing the Display Cable: étape 12, image 1 de 1
    • Route the display cable through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 15 5566 Display Assembly Replacement, Sliding the Display Cable: étape 13, image 1 de 1
    • Slide the display cable to the connector and press down on the latch to connect the display cable to the system board.
  13. Dell Inspiron 15 5566 Display Assembly Replacement, Routing the Antenna Cable: étape 14, image 1 de 1
    • Route the antenna cable through the routing guides on the palm-rest assembly.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,907
