Aller au contenu principal
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
[deleted]
[deleted] et 4 autres contributeurs
Dernière mise à jour le May 24, 2022
4 - 10 minutes
Modérée
A besoin de meilleures images
In most cases, a hard drive will need to be replaced because it has experienced a hardware failure. Hardware failure can occur for a variety of reasons, including exposure to extreme temperatures, ineffective cleaning routines, human error, lack of performance checks and maintenance, or that the technology is overdue for replacement. Upgrading your Dell Inspiron 15 5577 gaming hard drive can increase the speed and effectiveness of your device. Eventually, a replacement will need to be made.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: étape 1, image 1 de 1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 2, image 1 de 1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 3, image 1 de 1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 4, image 1 de 1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 5, image 1 de 1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 6, image 1 de 1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 7, image 1 de 1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
[deleted]
Membre depuis le 10/31/19
346 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 30
Total : 810
