Aller au contenu principal
Dell Inspiron 15 7590 2-in-1 Keys Replacement
Ojonukpemi F Ameh
Ojonukpemi F Ameh et 2 autres contributeurs
Dernière mise à jour le March 28, 2024
5 minutes
Facile
Outils incorrects
A spoiled laptop key can be very annoying to work with. Trying to use your laptop with a stuck key, or an empty space where a key should be, gets old very fast.
This guide goes over replacing Dell’s Inspiron 15 7590 2-in-1 laptop keys, which are a little tricky due to Dell’s usage of more than one keyboard manufacturer for the exact same model.
A quick tip is to take a look under the key to be replaced and reference that with the key types on any old site for replacements. The key types for the 7590 I’ve encountered are D36, D44, and D81 but make sure your keyboard matches your replacement.
This guide then comes in as a great next step and will help in removing and replacing your bad keys.
Ce dont vous avez besoin
Pièces
Outils
  • Spudger
    Spudger
Afficher plus…
  1. Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: étape 1, image 1 de 2 Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: étape 1, image 2 de 2
    • Position a spudger between the key cap and its hinge.
    • Push up with steady force to snap the key cap away from the hinge.
    • Use a spudger to pry under the corners of the hinge to remove it.
    • Remember the orientation of your key hinge and which holes go to the upper metal holders.
  2. Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 2, image 2 de 2
    • Align the new hinge with the metal holders on the keyboard.
    • Push the hinge into place and lock it onto the metal holders.
    • Make sure the hinge lies flat on the metal holders. If it doesn't, check the orientation of the hinge.
  3. Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 3, image 1 de 2 Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 3, image 2 de 2
    • Flip the key cap over and determine the positions of the spikes jutting out.
    • Align the spikes with the holes on the hinge and press the key cap onto the hinge.
  4. Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 4, image 1 de 1
    • Press down on the key to snap it into place.
  5. Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 5, image 1 de 3 Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 5, image 2 de 3 Dell Inspiron 15 7590 2-in-1 Keys Replacement: étape 5, image 3 de 3
    • To replace big keys, examine the other side of the key cap and locate the metal wires attached to the holders on the back of the key.
    • Examine the space the key will enter, and locate the metal holders with holes in them.
    • Position the key so all the metal ends can enter a hole and insert the metal ends into the holes.
    • Push down on the key and adjust the keycap to make sure its metal attachments slide into their holders.
If you encountered unsolvable difficulties replacing a key, make sure it’s aligned properly and crosscheck that the key is the same model as your laptop.
Ojonukpemi F Ameh
Membre depuis le 03/22/21
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G1, Sinclaire Spring 2021 Membre de l'équipe UMass Dartmouth, Team S1-G1, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G1
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 104
Total : 3,314
