Aller au contenu principal
Dell Inspiron 15-3543 Hard Drive Replacement
Brianna Blackburn
Brianna Blackburn et un autre contributeur
Dernière mise à jour le June 4, 2018
5 minutes
Facile
Is the hard drive in your Dell Inspiron 15-3543 failing, or has it already failed? If so, here is the guide to fix the problem by simply replacing your disk drive. All you need is the standard #0 Phillips Screwdriver head in order to remove the two screws involved with this replacement.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 15-3543 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 Dell Inspiron 15-3543 Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Flip the device over so the bottom is facing up.
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of laptop beside the vents.
  2. Dell Inspiron 15-3543 Hard Drive Replacement: étape 2, image 1 de 2 Dell Inspiron 15-3543 Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
  3. Dell Inspiron 15-3543 Hard Drive Replacement: étape 3, image 1 de 2 Dell Inspiron 15-3543 Hard Drive Replacement: étape 3, image 2 de 2
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw beside the black pull tab on the hard drive to the bottom left of the device.
  4. Dell Inspiron 15-3543 Hard Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 15-3543 Hard Drive Replacement: étape 4, image 2 de 2
    • Pull the black tab up and to the left to completely remove the hard drive.
3 autres ont terminé cette réparation.
Brianna Blackburn
Membre depuis le 01/23/18
954 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 43
Total : 1,968
