Dell Inspiron 15-3543 Hard Drive Replacement
Introduction
Passez à l'étape 1Is the hard drive in your Dell Inspiron 15-3543 failing, or has it already failed? If so, here is the guide to fix the problem by simply replacing your disk drive. All you need is the standard #0 Phillips Screwdriver head in order to remove the two screws involved with this replacement.
Ce dont vous avez besoin
Outils
Flip the device over so the bottom is facing up.
Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of laptop beside the vents.
3 autres ont terminé cette réparation.
