Dell Inspiron 15-3543 RAM Replacement
Introduction
Passez à l'étape 1Is the RAM in your Dell Inspiron 15-3543 defective or full? If so, here is the guide to fix the problem by simply replacing your RAM. All you need is the standard #0 Phillips Screwdriver head in order to remove the one screw involved with this replacement.
Ce dont vous avez besoin
Outils
Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
