Aller au contenu principal
Dell Inspiron 15-5559 RAM Replacement
Kyla Ward
Kyla Ward et 2 autres contributeurs
Dernière mise à jour le June 1, 2018
2 - 3 minutes
Facile
Before you attempt this guide make sure your device is not connected to a power source and be sure that the battery is removed. This guide is relatively easy and doesn't require any special skills.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Dell Inspiron 15-5559 RAM Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 15-5559 RAM Replacement, Back Panel: étape 1, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 RAM Replacement: étape 2, image 1 de 2 Dell Inspiron 15-5559 RAM Replacement: étape 2, image 2 de 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 RAM Replacement, RAM: étape 3, image 1 de 3 Dell Inspiron 15-5559 RAM Replacement, RAM: étape 3, image 2 de 3 Dell Inspiron 15-5559 RAM Replacement, RAM: étape 3, image 3 de 3
    • Place a finger on each of the 2 metal prongs on either side of the RAM stick and apply light pressure to release the RAM stick.
    • Remove the first stick of RAM. Repeat this process for the second RAM stick.
Kyla Ward
Membre depuis le 03/19/18
649 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S5-G5, Williams Spring 2018 Membre de l'équipe Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 1,743
