Aller au contenu principal
Dell Inspiron 15-5565 Battery Replacement
Avery Wasylyszyn
Avery Wasylyszyn et 4 autres contributeurs
Dernière mise à jour le May 31, 2023
15 minutes
Très facile
In this guide, you will successfully learn how to replace the battery in a Dell Inspiron 15-5565. Please see this page to perform troubleshooting.
Swollen batteries need to be replaced and should not be used. Visit this page for information on how to dispose of a swollen battery.
If the battery is stuck due to swelling, do not try to remove the battery yourself and seek professional assistance. For this device you can contact Dell Technical support to assist in this matter.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 15-5565 Battery Replacement, Optical Drive: étape 1, image 1 de 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 2, image 3 de 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Battery Replacement, Back Cover: étape 3, image 1 de 2 Dell Inspiron 15-5565 Battery Replacement, Back Cover: étape 3, image 2 de 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 15-5565 Battery Replacement: étape 4, image 2 de 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Battery Replacement, Battery: étape 5, image 1 de 2 Dell Inspiron 15-5565 Battery Replacement, Battery: étape 5, image 2 de 2
    • Remove the three 5 mm screws from the battery bracket using a Phillips #00 screwdriver.
  6. Dell Inspiron 15-5565 Battery Replacement: étape 6, image 1 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 6, image 2 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 6, image 3 de 3
    • Remove the five 5 mm screws from the outer edges of the battery using a Phillips #00 screwdriver.
    • Remove the battery from the laptop.
Avery Wasylyszyn
Membre depuis le 03/08/23
228 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 27
Total : 446
