Aller au contenu principal
Dell Inspiron 15-7548  Battery Replacement
Christopher Fisher
Christopher Fisher et 3 autres contributeurs
Dernière mise à jour le January 3, 2019
9 - 10 minutes
Facile
This guide will walk you through the process of replacing a dead or damaged battery in your Dell Inspiron 15-7548.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Dell Inspiron 15-7548  Battery Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 15-7548  Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548  Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 15-7548  Battery Replacement: étape 2, image 2 de 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548  Battery Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15-7548  Battery Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548  Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7548  Battery Replacement: étape 4, image 2 de 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
4 autres ont terminé cette réparation.
Christopher Fisher
Membre depuis le 09/26/18
409 Réputation
4 tutoriels rédigés
Équipe
Un commentaire
Little grey piece on the cable popped off, will that affect anything? Laptop isn’t recognizing that it has a battery after I took it out and put it back in.
Taylor - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 22
Total : 2,637
