Aller au contenu principal
Dell Inspiron 15-7559 Repair Memory Modules Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 16, 2019
5 - 8 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Memory Modules.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Repair Memory Modules Replacement: étape 2, image 1 de 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: étape 2, image 2 de 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: étape 2, image 3 de 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Repair Memory Modules Replacement: étape 3, image 1 de 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: étape 3, image 2 de 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: étape 3, image 3 de 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Popping up the Memory Module: étape 4, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  5. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: étape 5, image 1 de 1
    • Slide and remove the memory module from the memory-module slot.
  6. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Align the Notch: étape 6, image 1 de 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  7. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: étape 7, image 1 de 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Terrence15
Membre depuis le 12/18/17
79 585 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 1,190
