Aller au contenu principal
Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 23, 2019
9 - 15 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: étape 2, image 1 de 1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: étape 3, image 1 de 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Bracket: étape 5, image 1 de 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Align the Screw Holes: étape 6, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: étape 8, image 1 de 1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: étape 9, image 1 de 1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 973
