Aller au contenu principal
Dell Inspiron 17-3721 Keyboard Replacement
Kevin Prairie
Kevin Prairie et 2 autres contributeurs
Dernière mise à jour le May 9, 2018
2 - 5 minutes
Facile
Malfunctioning keys or a completely broken keyboard can render a laptop useless to the user. This guide will show the steps to replace the keyboard of this device.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron 17-3721 Keyboard Replacement: étape 2, image 2 de 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
Kevin Prairie
Membre depuis le 03/20/18
445 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
3 membres
7 tutoriels rédigés
Un commentaire
Wow that was easy! Thanks :D
Isaac Pettis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 22
Total : 470
