Dell Inspiron 1721 Back Cover Replacement
Introduction
Passez à l'étape 1If you are experiencing any problems with the device not reading a disk, overheating, or any other issues with an interior part of the Dell Inspiron 1721 this guide can be a helpful starting place for getting access to remove or replace any components.
Before attempting to take the a back cover off make sure that the device is completely turned off.
Ce dont vous avez besoin
Slide tabs outward to undo the locks.
Grab and pull the battery away from the device to remove.
Pry up on the corner of the hinge cover with an iFixit opening tool.
Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
Lean the display back as far as it goes and lift up on the hinge cover to remove.
