Aller au contenu principal
Dell Inspiron 17R-5737 Battery Replacement
David Callahan
David Callahan et 3 autres contributeurs
Dernière mise à jour le January 4, 2018
30 secondes
Très facile
For replacing any part of your device, this will be your first step. If we do not remove the power supply, we may risk accidentally short-circuiting the laptop or even shocking and harming ourselves.
  1. Dell Inspiron 17R-5737 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 17R-5737 Battery Replacement: étape 2, image 2 de 2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 17R-5737 Battery Replacement: étape 3, image 2 de 2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
David Callahan
Membre depuis le 10/19/17
559 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 18
Total : 722
