Dell Inspiron 3148 Fan Replacement
Introduction
Passez à l'étape 1Is your computer heating up easily or getting louder? Consider using this guide to replace the fan in your device.
Ce dont vous avez besoin
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
If there is tape on your fan, remove the tape.
Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
