Aller au contenu principal
Dell Inspiron 3148 WLAN Card Replacement
Christopher Gravelle
Christopher Gravelle et un autre contributeur
Dernière mise à jour le December 18, 2018
10 - 15 minutes
Modérée
Photos d’action
Is your computer experiencing problems with connecting to the Wi-Fi or the internet? Consider using this guide to replace the WLAN card in your device.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 3148 WLAN Card Replacement, Back Panel: étape 1, image 2 de 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: étape 2, image 1 de 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: étape 3, image 1 de 2 Dell Inspiron 3148 WLAN Card Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: étape 4, image 1 de 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: étape 4, image 2 de 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: étape 4, image 3 de 3
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: étape 5, image 1 de 1
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: étape 6, image 1 de 2 Dell Inspiron 3148 WLAN Card Replacement: étape 6, image 2 de 2
    • Using your fingers, pull the WLAN card up and away from the device.
Membre depuis le 10/23/18
837 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 13
Total : 316
