Aller au contenu principal
Dell Inspiron 3542 Hard Drive Replacement
Rachel lindsey
Rachel lindsey et 9 autres contributeurs
Dernière mise à jour le November 16, 2022
5 - 15 minutes
Facile
Outils incorrects
This guide provides steps on how to remove and replace the hard drive for the Dell Inpiron 3542. This will allow you to carefully remove and replace your hard drive if broken, or if you want to upgrade the hard drive.
The hard drive is the device in your computer that stores and retrieves the data that you have saved. If you are running low on space, upgrading your hard drive would allow you to have more space and continue to work. If your hard drive fails, replacing your hard drive will allow you to continue using your computer.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Dell Inspiron 3542 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 Dell Inspiron 3542 Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Flip computer over to the bottom and slide the latches on both sides of battery outwards.
    • Remove the battery from computer.
  2. Dell Inspiron 3542 Hard Drive Replacement: étape 2, image 1 de 2 Dell Inspiron 3542 Hard Drive Replacement: étape 2, image 2 de 2
    • Using a T5 Torx screwdriver, remove a M2.5 x 5mm screw.
    • Slide up on the access door to remove it.
  3. Dell Inspiron 3542 Hard Drive Replacement: étape 3, image 1 de 3 Dell Inspiron 3542 Hard Drive Replacement: étape 3, image 2 de 3 Dell Inspiron 3542 Hard Drive Replacement: étape 3, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the 1 x M2 x 3mm screw.
    • The hard drive can now be slid out of the computer.
Rachel lindsey
Membre depuis le 03/21/17
733 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S46-G1, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 32
Total : 3,484
