Aller au contenu principal
Dell Inspiron 6000 Screen Replacement
Jacob DeWar
Jacob DeWar et 4 autres contributeurs
Dernière mise à jour le January 8, 2015
15 - 20 minutes
Modérée
Replacing the screen takes some time and effort, but requires few tools.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Afficher plus…
  1. Dell Inspiron 6000 Screen Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Screen Replacement: étape 2, image 1 de 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: étape 3, image 1 de 3 Dell Inspiron 6000 Screen Replacement, Keyboard: étape 3, image 2 de 3 Dell Inspiron 6000 Screen Replacement, Keyboard: étape 3, image 3 de 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Screen Replacement: étape 4, image 1 de 2 Dell Inspiron 6000 Screen Replacement: étape 4, image 2 de 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Screen Replacement: étape 5, image 1 de 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Screen Replacement: étape 6, image 1 de 3 Dell Inspiron 6000 Screen Replacement: étape 6, image 2 de 3 Dell Inspiron 6000 Screen Replacement: étape 6, image 3 de 3
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Screen Replacement, Screen: étape 7, image 1 de 1
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
  8. Dell Inspiron 6000 Screen Replacement: étape 8, image 1 de 1
    • Pull and disconnect the blue tab.
  9. Dell Inspiron 6000 Screen Replacement: étape 9, image 1 de 1
    • Disconnect the black and white wires.
  10. Dell Inspiron 6000 Screen Replacement: étape 10, image 1 de 1
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
  11. Dell Inspiron 6000 Screen Replacement: étape 11, image 1 de 1
    • Separate the top panel of the laptop from the bottom panel.
  12. Dell Inspiron 6000 Screen Replacement: étape 12, image 1 de 2 Dell Inspiron 6000 Screen Replacement: étape 12, image 2 de 2
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
  13. Dell Inspiron 6000 Screen Replacement: étape 13, image 1 de 2 Dell Inspiron 6000 Screen Replacement: étape 13, image 2 de 2
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
  14. Dell Inspiron 6000 Screen Replacement: étape 14, image 1 de 2 Dell Inspiron 6000 Screen Replacement: étape 14, image 2 de 2
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
  15. Dell Inspiron 6000 Screen Replacement: étape 15, image 1 de 2 Dell Inspiron 6000 Screen Replacement: étape 15, image 2 de 2
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
3 autres ont terminé cette réparation.
Jacob DeWar
Membre depuis le 09/23/14
533 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 11-1, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 19
Total : 2,698
