Dell Inspiron 7568 Display Assembly Replacement Guide
Introduction
Passez à l'étape 1By following the steps in this guide one should be able to replace the complete display assembly on the a Dell Inspiron 7568.
Ce dont vous avez besoin
Outils
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
Doing this will allow one to access the LCD-motherboard connector cables.
2 autres ont terminé cette réparation.
