Dell Inspiron 910 Touchpad Buttons Replacement
Introduction
Passez à l'étape 1This guide will teach you how to remove the buttons below the track pad from the laptop device.
Ce dont vous avez besoin
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
Remove the seven Phillips #00 screws that hold the metal component to the frame
Detach the two ribbon cables on either side of the silver panel
Gently lift the silver panel from the laptop using the plastic opening tool
Set the laptop aside
