Dell Inspiron B130 Fan Replacement
Introduction
Passez à l'étape 1This guide will show you how to replace the cooling fan for your Dell B130. The cooling fan keeps the internals of the laptop cool so it can run efficiently. Some problems that arise when this is not functioning correctly is when the computer will turn off suddenly or it is running very slow.
Ce dont vous avez besoin
Remove the battery by flipping the two switches under the battery and pulling it out
Remove the 8mm screw
Use the plastic opening tool to push out the disk drive.
Pull the disk drive out with the opposite hand.
This particular computer is missing its hard drive.
Remove the two screws.
Remove the plastic cover by lifting from the groove as indicated.
Remove the hard drive from the computer by lifting up and out.
Put down the computer and open up the screen.
There is a long piece of plastic underneath the screen that you will have to remove.
After opening the panel, you will see two cable connections attached to the screen.
Identify the one with blue tape this is the display connector that needs to be removed.
Locate the second connector next to the one removed in the previous step, This connector does not have blue tape but still needs to be detached. To remove it safely hold both sides of the connector firmly. Pull it straight apart avoid twisting or pulling at an angle to prevent damage.
Remove the three 6mm screws.
Lift the plastic cover off to reveal the RAM and the Wireless.
Use a Phillips #0 screwdriver to remove the twelve 8mm screws from the bottom of the laptop. Keep the screws organized to avoid losing them.
Turn the laptop over so that the keyboard side is facing up, then locate and remove the two 4mm screws positioned just below where the screen would be using a Phillips #0 screwdriver.
Remove the five remaining 6mm screws. Be sure to keep track of these screws, as they will be needed for reassembly.
Lift and remove the entire cover/frame from the top of the motherboard. Gently pull up to detach it without using excessive force
Remove the motherboard by pulling it upward and sliding it to the right. Be careful not to damage any remaining connectors or components. If the motherboard feels stuck, double-check that all screws and cables have been disconnected.
Remove these four 4 mm screws.
Turn the motherboard over and lift the fan up.
Disconnect the wire that connects the fan to the motherboard by pulling up gently.
You can now remove the fan.
