Aller au contenu principal
Dell Inspiron E1405 LCD Screen Replacement
Sarah Neal Secrest
Sarah Neal Secrest et 2 autres contributeurs
Dernière mise à jour le May 25, 2017
10 minutes
Modérée
A besoin de meilleures images
Nécessite plus d'images
This guide will help you replace the LCD screen in a Dell Inspiron 1305 laptop.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: étape 2, image 1 de 3 Dell Inspiron E1405 LCD Screen Replacement: étape 2, image 2 de 3 Dell Inspiron E1405 LCD Screen Replacement: étape 2, image 3 de 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: étape 3, image 1 de 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: étape 3, image 2 de 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: étape 3, image 3 de 3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: étape 4, image 1 de 1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: étape 5, image 1 de 3 Dell Inspiron E1405 LCD Screen Replacement: étape 5, image 2 de 3 Dell Inspiron E1405 LCD Screen Replacement: étape 5, image 3 de 3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: étape 6, image 1 de 2 Dell Inspiron E1405 LCD Screen Replacement: étape 6, image 2 de 2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: étape 7, image 1 de 2 Dell Inspiron E1405 LCD Screen Replacement: étape 7, image 2 de 2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
Sarah Neal Secrest
Membre depuis le 03/20/17
597 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S8-G3, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S8-G3, Bennett Spring 2017
TTU-BENNETT-S17S8G3
3 membres
5 tutoriels rédigés
1 commentaire de tutoriel
I need complete body *Dell INSPIRON E1405 .
St Master Fun - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 505
