Dell Inspiron E1505 Optical Drive Replacement
Ce dont vous avez besoin
Before any work can be done ensure that the laptop is powered off.
Use either the power button on the computer or issue a shutdown from the operating system.
Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
Remove the back panel: Use the screwdriver to remove the screws on the back panel.
Lift the back panel off the laptop to expose the interior of the laptop.
Locate the hard drive.
2 commentaires
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
