Aller au contenu principal
Dell Inspiron Mini 10 Palm Rest Bracket Replacement
Danielle Jarecki
Danielle Jarecki et 4 autres contributeurs
Dernière mise à jour le December 22, 2016
Aucune estimation
Modérée
Détails manquants
This guide will show you how to remove the palm rest bracket which holds the supports the hard drive bay and the palm rest. This part may need to be removed to access other components of the device including the motherboard and RAM module.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Keyboard: étape 3, image 1 de 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 4, image 1 de 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 5, image 1 de 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 5, image 2 de 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 6, image 1 de 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 6, image 2 de 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  7. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Palm Rest Bracket: étape 7, image 1 de 1
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  8. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 8, image 1 de 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 8, image 2 de 2
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  9. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 9, image 1 de 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 9, image 2 de 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  10. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 10, image 1 de 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 10, image 2 de 2
    • Remove the four 6mm Philips 0 screws securing the bracket.
  11. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 11, image 1 de 3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 11, image 2 de 3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 11, image 3 de 3
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  12. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: étape 12, image 1 de 1
    • Gently pry off the bracket using the prying tool.
Danielle Jarecki
Membre depuis le 10/21/16
334 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 295
