Aller au contenu principal
Dell Inspiron Mini 10 Touchpad Replacement
Angela Wild
Angela Wild et 3 autres contributeurs
Dernière mise à jour le December 22, 2016
3 minutes
Facile
This guide will provide basic information for:
  • Replacing components of the device.
  • Disassembling the device to reach and repair the touchpad.
  • Precautions for preventing further damage.
  • Required tools for replacement.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron Mini 10 Touchpad Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Touchpad Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: étape 3, image 1 de 2 Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: étape 3, image 2 de 2
    • Using a spudger, gently pry the palm rest off of the palm rest bracket.
    • Carefully remove the palm rest from the computer base to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Touchpad Replacement: étape 4, image 1 de 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Touchpad Replacement: étape 5, image 1 de 3 Dell Inspiron Mini 10 Touchpad Replacement: étape 5, image 2 de 3 Dell Inspiron Mini 10 Touchpad Replacement: étape 5, image 3 de 3
    • Turn the palm rest assembly over.
    • Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
    • Gently lift the copper and silver foil squares on the touchpad.
    • Remove the touchpad from the palm rest.
Angela Wild
Membre depuis le 10/26/16
104 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team 1-4, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 650
