Aller au contenu principal
Dell Latitude E4200 LED Cover Replacement
Hezekiah Brown
Hezekiah Brown et un autre contributeur
Dernière mise à jour le June 18, 2021
1 - 3 minutes
Facile
Photos d’action
A besoin de meilleures images
Nécessite plus d'images
Tutoriel réalisé par la communauté
Meilleure introduction
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery from the computer.
  1. Dell Latitude E4200 LED Cover Replacement, Open the display all the way.: étape 2, image 1 de 1
    • Open the display all the way (160 degrees).
    • To avoid damaging the LED cover, do not lift the cover on both sides simultaneously. Removing the LED cover in a different way than described may cause the plastic to break.
    • Starting on the right side of the computer, use a plastic scribe (inserted into the indent) to pry up the hinge cover. Lift the bottom edge of the cover away from the keyboard going from the right to the left, and then pull the cover up and away from the display to remove it.
    • Before installing the LED cover, ensure that all cables are routed correctly. Improper routing of the cables can cause damage to the cables.
    • Insert the tabs on the top edge of the cover into the slots under the bottom edge of the display.
    • Press from left to right until the cover snaps into place, ensuring that the edges of the cover line up with those on the palm rest.
Hezekiah Brown
Membre depuis le 02/11/21
6 169 Réputation
49 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 132
