Aller au contenu principal
Dell Latitude E5500 Bluetooth Card Replacement
Richard Harrison
Richard Harrison et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
10 minutes
Facile
If the user would like to replace a faulty Bluetooth card, or one that is not powerful enough, this guide will give step by step information on how to achieve this.
Ce dont vous avez besoin
Outils
  1. Dell Latitude E5500 Bluetooth Card Replacement, Bluetooth Card: étape 1, image 1 de 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Bluetooth Card Replacement: étape 2, image 1 de 2 Dell Latitude E5500 Bluetooth Card Replacement: étape 2, image 2 de 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Bluetooth Card Replacement: étape 3, image 1 de 2 Dell Latitude E5500 Bluetooth Card Replacement: étape 3, image 2 de 2
    • The Bluetooth card is located near the front of the device, and is the expansion card with one antenna attached to it.
  4. Dell Latitude E5500 Bluetooth Card Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the wire connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Bluetooth Card Replacement: étape 5, image 1 de 1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Bluetooth Card Replacement: étape 6, image 1 de 2 Dell Latitude E5500 Bluetooth Card Replacement: étape 6, image 2 de 2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
4 autres ont terminé cette réparation.
Richard Harrison
Membre depuis le 10/23/16
805 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 29
Total : 2,626
