Aller au contenu principal
Dell Latitude E6420 Screen Replacement
Madysen Eames
Madysen Eames et un autre contributeur
Dernière mise à jour le May 23, 2018
10 minutes
Modérée
Laptop screens can crack or stop displaying picture. This guide will show users how to replace the screen.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Latitude E6420 Screen Replacement, Battery: étape 1, image 1 de 2 Dell Latitude E6420 Screen Replacement, Battery: étape 1, image 2 de 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Screen Replacement: étape 2, image 1 de 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Screen Replacement, Screen: étape 3, image 1 de 2 Dell Latitude E6420 Screen Replacement, Screen: étape 3, image 2 de 2
    • Open the laptop and lay it flat on your work surface.
    • Using the spudger, lift the bezel up from around the laptop screen.
  4. Dell Latitude E6420 Screen Replacement: étape 4, image 1 de 3 Dell Latitude E6420 Screen Replacement: étape 4, image 2 de 3 Dell Latitude E6420 Screen Replacement: étape 4, image 3 de 3
    • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
    • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
    • Lift the screen.
  5. Dell Latitude E6420 Screen Replacement: étape 5, image 1 de 1
    • Lift the laptop screen and flip it over to lay it on top of the keyboard.
  6. Dell Latitude E6420 Screen Replacement: étape 6, image 1 de 2 Dell Latitude E6420 Screen Replacement: étape 6, image 2 de 2
    • Remove the piece of tape from the back of the LCD cable.
  7. Dell Latitude E6420 Screen Replacement: étape 7, image 1 de 2 Dell Latitude E6420 Screen Replacement: étape 7, image 2 de 2
    • Lift the piece of tape attached to the LCD cable.
    • Once the tape has lifted, gently pull back to unplug the LCD cable.
9 autres ont terminé cette réparation.
Madysen Eames
Membre depuis le 02/27/18
1 555 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 membres
7 tutoriels rédigés
Un commentaire
Bonjour, Merci
endibos - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 35
Total : 4,197
