Aller au contenu principal
Dell Precision 7560 Keyboard Replacement
Jack Allred
Jack Allred et 2 autres contributeurs
Dernière mise à jour le June 6, 2023
10 - 15 minutes
Modérée
The guide shows how to remove the keyboard from a Dell Precision 7560. The keyboard is a core component of the computer, so keeping on top of its maintenance is vital. If the issue with the keyboard isn't merely debris keeping a key from functioning, then this guide will assist you in replacing the keyboard entirely.
Ce dont vous avez besoin
Outils
  1. Dell Precision 7560 Keyboard Replacement, Battery: étape 1, image 1 de 3 Dell Precision 7560 Keyboard Replacement, Battery: étape 1, image 2 de 3 Dell Precision 7560 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: étape 2, image 1 de 3 Dell Precision 7560 Keyboard Replacement: étape 2, image 2 de 3 Dell Precision 7560 Keyboard Replacement: étape 2, image 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: étape 3, image 1 de 3 Dell Precision 7560 Keyboard Replacement: étape 3, image 2 de 3 Dell Precision 7560 Keyboard Replacement: étape 3, image 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Dell Precision 7560 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Dell Precision 7560 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: étape 5, image 1 de 3 Dell Precision 7560 Keyboard Replacement: étape 5, image 2 de 3 Dell Precision 7560 Keyboard Replacement: étape 5, image 3 de 3
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: étape 6, image 1 de 3 Dell Precision 7560 Keyboard Replacement: étape 6, image 2 de 3 Dell Precision 7560 Keyboard Replacement: étape 6, image 3 de 3
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
2 autres ont terminé cette réparation.
Jack Allred
Membre depuis le 02/09/23
345 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-1, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-1, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G1
3 membres
6 tutoriels rédigés
Un commentaire
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 53
Total : 1,055
