Aller au contenu principal
Dell Precision 7560 Solid-State Drive (SSD) Replacement
Hector
Hector et 3 autres contributeurs
Dernière mise à jour le June 6, 2023
10 minutes
Modérée
This guide covers how to replace the solid-state drive (SSD) on a Dell Precision 7560 laptop. The SSD is responsible for storing data from your device permanently in memory. Before continuing to the guide, please make sure that the device's battery is removed. Please refer to our Dell Precision 7560 Battery replacement guide. This will prevent data from being lost and will prevent the risk of circuit fires.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: étape 1, image 1 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: étape 1, image 2 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: étape 1, image 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 2, image 1 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 2, image 2 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 2, image 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 3, image 1 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 3, image 2 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 3, image 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): étape 4, image 1 de 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): étape 4, image 2 de 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 5, image 1 de 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: étape 5, image 2 de 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
Hector
Membre depuis le 02/14/23
261 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-1, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-1, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G1
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 38
Total : 879
