Aller au contenu principal
Dell Precision 7560 Speaker Replacement
Neevia Vinod
Neevia Vinod et 2 autres contributeurs
Dernière mise à jour le June 19, 2024
30 minutes
Modérée
Images incohérentes
Use this guide to replace a faulty speaker in your Dell Precision 7560 laptop.
The speakers are responsible for the sound you hear when you play music, watch videos or do anything else that involves the audio on your laptop. If you notice distorted audio or no audio at all from your laptop, you should replace your speaker.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this guide.
Ce dont vous avez besoin
Outils
  1. Dell Precision 7560 Speaker Replacement, Battery: étape 1, image 1 de 3 Dell Precision 7560 Speaker Replacement, Battery: étape 1, image 2 de 3 Dell Precision 7560 Speaker Replacement, Battery: étape 1, image 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Speaker Replacement: étape 2, image 1 de 3 Dell Precision 7560 Speaker Replacement: étape 2, image 2 de 3 Dell Precision 7560 Speaker Replacement: étape 2, image 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Speaker Replacement: étape 3, image 1 de 3 Dell Precision 7560 Speaker Replacement: étape 3, image 2 de 3 Dell Precision 7560 Speaker Replacement: étape 3, image 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): étape 4, image 1 de 2 Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): étape 4, image 2 de 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Speaker Replacement: étape 5, image 1 de 2 Dell Precision 7560 Speaker Replacement: étape 5, image 2 de 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
  6. Dell Precision 7560 Speaker Replacement, Speaker: étape 6, image 1 de 3 Dell Precision 7560 Speaker Replacement, Speaker: étape 6, image 2 de 3 Dell Precision 7560 Speaker Replacement, Speaker: étape 6, image 3 de 3
    • Loosen the eight captive screws that secure the fan assembly using a Phillips #0 screwdriver.
    • Lifting from the bottom, carefully remove the fan.
  7. Dell Precision 7560 Speaker Replacement: étape 7, image 1 de 3 Dell Precision 7560 Speaker Replacement: étape 7, image 2 de 3 Dell Precision 7560 Speaker Replacement: étape 7, image 3 de 3
    • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Remove the metal overlay.
    • Disconnect the wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card.
  8. Dell Precision 7560 Speaker Replacement: étape 8, image 1 de 2 Dell Precision 7560 Speaker Replacement: étape 8, image 2 de 2
    • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
    • Remove, carefully and completely, any wires running over the frame.
    • Lift the metal frame.
  9. Dell Precision 7560 Speaker Replacement: étape 9, image 1 de 2 Dell Precision 7560 Speaker Replacement: étape 9, image 2 de 2
    • Flip up the metal edge holding down the SD connection.
    • Gently pull to disconnect the metal connecting wire.
  10. Dell Precision 7560 Speaker Replacement: étape 10, image 1 de 3 Dell Precision 7560 Speaker Replacement: étape 10, image 2 de 3 Dell Precision 7560 Speaker Replacement: étape 10, image 3 de 3
    • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
    • Remove the metal cap.
    • Disconnect the wire bundle.
  11. Dell Precision 7560 Speaker Replacement: étape 11, image 1 de 3 Dell Precision 7560 Speaker Replacement: étape 11, image 2 de 3 Dell Precision 7560 Speaker Replacement: étape 11, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
    • Carefully remove the speaker wire from the motherboard.
  12. Dell Precision 7560 Speaker Replacement: étape 12, image 1 de 2 Dell Precision 7560 Speaker Replacement: étape 12, image 2 de 2
    • Using both hands, carefully lift and remove the speaker.
Neevia Vinod
Membre depuis le 02/08/24
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 128
