Aller au contenu principal
Dell Precision M6700 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond et 2 autres contributeurs
Dernière mise à jour le November 15, 2022
10 - 20 minutes
Modérée
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Dell Precision M6700 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Dell Precision M6700 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M6700 Hard Drive Replacement, Base Cover: étape 2, image 1 de 2 Dell Precision M6700 Hard Drive Replacement, Base Cover: étape 2, image 2 de 2
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer
  3. Dell Precision M6700 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the screws that secure the primary hard drive to the computer. Slide the primary hard -drive latch to the unlock position and pull out the hard drive from the computer.
  4. Dell Precision M6700 Hard Drive Replacement: étape 4, image 1 de 1
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
  5. Dell Precision M6700 Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the screw that secure that secondary hard drive in place.
    • Pull the tab upward and remove the secondary hard drive from the computer.
  6. Dell Precision M6700 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the screw that secure secondary hard drive to the bracket.
    • Remove the secondary hard drive from the bracket.
4 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
45 210 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 28
Total : 5,118
