Aller au contenu principal
Dell Vostro 1400 Screen Replacement
David Hogg
David Hogg et 4 autres contributeurs
Dernière mise à jour le May 25, 2017
10 minutes
Modérée
A besoin de meilleures images
This guide will show you the proper steps to replace your screen on your Dell Vostro 1400
Ce dont vous avez besoin
Outils
  1. Dell Vostro 1400 Screen Replacement, Battery: étape 1, image 1 de 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: étape 2, image 1 de 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: étape 3, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 3, image 2 de 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: étape 4, image 1 de 1
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: étape 5, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 5, image 2 de 2
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: étape 6, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 6, image 2 de 2
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: étape 7, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 7, image 2 de 2
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: étape 8, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 8, image 2 de 2
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: étape 9, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 9, image 2 de 2
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: étape 10, image 1 de 3 Dell Vostro 1400 Screen Replacement: étape 10, image 2 de 3 Dell Vostro 1400 Screen Replacement: étape 10, image 3 de 3
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: étape 11, image 1 de 2 Dell Vostro 1400 Screen Replacement: étape 11, image 2 de 2
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
2 autres ont terminé cette réparation.
David Hogg
Membre depuis le 03/20/17
739 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S8-G2, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S8-G2, Bennett Spring 2017
TTU-BENNETT-S17S8G2
4 membres
5 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 20
Total : 691
