Aller au contenu principal
Dell Vostro 1400 Speakers Replacement
David Hogg
David Hogg et 7 autres contributeurs
Dernière mise à jour le June 28, 2024
45 minutes
Difficile
Photos d’action
A besoin de meilleures images
Nécessite plus d'images
Étapes manquantes
This guide will show you the proper steps to replace your speakers in your Dell Vostro 1400 Laptop.
Computer speakers allow any audio played to be transmitted out loud without the use of headphones. Speakers that are not functional will produce either distorted sound or no sound at all.
Before using this guide, make sure to remove the hard drive, the battery, and the RAM.
Before beginning, make sure the device is powered off and disconnected from any power source.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Dell Vostro 1400 Speakers Replacement, Battery: étape 1, image 1 de 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Speakers Replacement: étape 2, image 1 de 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Speakers Replacement: étape 3, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 3, image 2 de 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Speakers Replacement, Hard Drive: étape 4, image 1 de 2 Dell Vostro 1400 Speakers Replacement, Hard Drive: étape 4, image 2 de 2
    • Please ensure that your device is turned off and everything is unplugged before working on it.
    • Unscrew both screws on the hard drive panel until the panel is able to be removed.
    • The screws will not come off of the panel.
    • Once screws have been loosened, remove the panel from the laptop.
  5. Dell Vostro 1400 Speakers Replacement: étape 5, image 1 de 1
    • Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
  6. Dell Vostro 1400 Speakers Replacement, RAM: étape 6, image 1 de 2 Dell Vostro 1400 Speakers Replacement, RAM: étape 6, image 2 de 2
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  7. Dell Vostro 1400 Speakers Replacement: étape 7, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 7, image 2 de 2
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
  8. Dell Vostro 1400 Speakers Replacement, Speakers: étape 8, image 1 de 3 Dell Vostro 1400 Speakers Replacement, Speakers: étape 8, image 2 de 3 Dell Vostro 1400 Speakers Replacement, Speakers: étape 8, image 3 de 3
    • Make sure device is turned off
    • Loosen the 3 screws holding down the panel for the CPU processor door.
    • Loosen the 4 heat sink screws and lift the heat sink away from the motherboard.
  9. Dell Vostro 1400 Speakers Replacement: étape 9, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 9, image 2 de 2
    • Use a flat head screw driver to turn the CPU locking screw counter clockwise to 180 degrees.
    • Lift CPU processor away from the motherboard
  10. Dell Vostro 1400 Speakers Replacement: étape 10, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 10, image 2 de 2
    • Remove the seventeen 8mm bottom base screws.
    • Remove the two 8mm screws from the back.
  11. Dell Vostro 1400 Speakers Replacement: étape 11, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 11, image 2 de 2
    • Remove the three 3mm bottom base screws.
    • Remove the 5mm bottom base screw.
  12. Dell Vostro 1400 Speakers Replacement: étape 12, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 12, image 2 de 2
    • Turn over the laptop and open it.
    • Using a flat head screw driver, pry up the power button cover starting right to left.
  13. Dell Vostro 1400 Speakers Replacement: étape 13, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 13, image 2 de 2
    • Unscrew the (2) 2mm x 3mm screws.
    • Carefully lift the keyboard and hold it over the power button.
  14. Dell Vostro 1400 Speakers Replacement: étape 14, image 1 de 3 Dell Vostro 1400 Speakers Replacement: étape 14, image 2 de 3 Dell Vostro 1400 Speakers Replacement: étape 14, image 3 de 3
    • Carefully lift up the blue latch on the keyboard cable connector and slide the cable out.
  15. Dell Vostro 1400 Speakers Replacement: étape 15, image 1 de 1
    • Remove the left and the right hinge covers.
  16. Dell Vostro 1400 Speakers Replacement: étape 16, image 1 de 3 Dell Vostro 1400 Speakers Replacement: étape 16, image 2 de 3 Dell Vostro 1400 Speakers Replacement: étape 16, image 3 de 3
    • Unplug the WLAN antenna cables.
    • Unscrew the 2mm x 3mm screw.
    • Remove the WLAN card from the motherboard.
  17. Dell Vostro 1400 Speakers Replacement: étape 17, image 1 de 1
    • Remove the 2mm x 3mm screw on the media button circuit board.
    • Loosen the media button circuit board and take the antenna cables from under it.
  18. Dell Vostro 1400 Speakers Replacement: étape 18, image 1 de 1
    • Unplug LCD cable
    • Lift LCD assembly away from the laptop
  19. Dell Vostro 1400 Speakers Replacement: étape 19, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 19, image 2 de 2
    • Remove the (3) 2.5mm x 5mm top palmrest screws
    • Unplug palm rest cables
  20. Dell Vostro 1400 Speakers Replacement: étape 20, image 1 de 2 Dell Vostro 1400 Speakers Replacement: étape 20, image 2 de 2
    • Remove the palm rest from the base of the laptop
  21. Dell Vostro 1400 Speakers Replacement: étape 21, image 1 de 3 Dell Vostro 1400 Speakers Replacement: étape 21, image 2 de 3 Dell Vostro 1400 Speakers Replacement: étape 21, image 3 de 3
    • Unplug the audio board cable and the speakers.
    • Remove the 2.5mm x 5mm screw.
  22. Dell Vostro 1400 Speakers Replacement: étape 22, image 1 de 3 Dell Vostro 1400 Speakers Replacement: étape 22, image 2 de 3 Dell Vostro 1400 Speakers Replacement: étape 22, image 3 de 3
    • Remove the (2) 2mm x 3mm screws.
    • Lift the motherboard out of the base and flip it over.
  23. Dell Vostro 1400 Speakers Replacement: étape 23, image 1 de 3 Dell Vostro 1400 Speakers Replacement: étape 23, image 2 de 3 Dell Vostro 1400 Speakers Replacement: étape 23, image 3 de 3
    • Remove the two 2.5mm x 5mm Right and Left speaker screws
    • Lift the speakers away from the base of the laptop.
David Hogg
Membre depuis le 03/20/17
739 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S8-G2, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S8-G2, Bennett Spring 2017
TTU-BENNETT-S17S8G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 1,052
