Aller au contenu principal
Dell Vostro 15 3568 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond et 2 autres contributeurs
Dernière mise à jour le December 5, 2021
15 - 30 minutes
Facile
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Afficher plus…
  1. Dell Vostro 15 3568 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3568 Hard Drive Replacement, KeyBoard: étape 2, image 1 de 1
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  3. Dell Vostro 15 3568 Hard Drive Replacement: étape 3, image 1 de 1
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  4. Dell Vostro 15 3568 Hard Drive Replacement, Base Cover: étape 4, image 1 de 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  5. Dell Vostro 15 3568 Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the screws that secure the base cover to the computer
  6. Dell Vostro 15 3568 Hard Drive Replacement: étape 6, image 1 de 1
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  7. Dell Vostro 15 3568 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 1
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
17 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
45 210 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 95
Total : 17,179
