Aller au contenu principal
Disassembling Canon PowerShot SD1100 IS Camera Lens
Tyler Grossheim
Tyler Grossheim et 4 autres contributeurs
Dernière mise à jour le January 28, 2014
25 - 35 minutes
Modérée
Tutoriel vedette
Use this guide to remove the camera lens piece.
Ce dont vous avez besoin
Outils
  1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: étape 1, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: étape 1, image 2 de 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 2, image 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 2, image 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 2, image 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 3, image 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 3, image 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 3, image 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 4, image 1 de 1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: étape 5, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: étape 5, image 2 de 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 6, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 6, image 2 de 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 7, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 7, image 2 de 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 9, image 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 9, image 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 9, image 3 de 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 10, image 1 de 1
    • The LCD screen should now be removed.
  11. Disassembling Canon PowerShot SD1100 IS Camera Lens, Flash Assembly: étape 11, image 1 de 1
    • Remove the screw located on the side of the camera (0.072 in).
  12. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 12, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 12, image 2 de 2
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  13. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 13, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 13, image 2 de 2
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  14. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 14, image 1 de 1
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  15. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 15, image 1 de 1
    • The capacitor should now be removed.
  16. Disassembling Canon PowerShot SD1100 IS Camera Lens, Camera Lens: étape 16, image 1 de 1
    • Remove 4 screws from silver plate (0.106 in).
  17. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 17, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 17, image 2 de 2
    • Use spudger to lift the second lens ribbon.
    • Remember the first ribbon was removed while taking out the flash assembly.
  18. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 18, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 18, image 2 de 2
    • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
  19. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 19, image 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 19, image 2 de 2
    • Remove the lens.
  20. Disassembling Canon PowerShot SD1100 IS Camera Lens: étape 20, image 1 de 1
    • The camera lens should now be removed.
17 autres ont terminé cette réparation.
Tyler Grossheim
Membre depuis le 01/25/11
1 551 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
1 commentaire de tutoriel
How do you CLEAN the lens?
Christian - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 94
Total : 21,792
