Aller au contenu principal
Disassembling Canon PowerShot SD1100 IS LCD screen
Tyler Grossheim
Tyler Grossheim et 6 autres contributeurs
Dernière mise à jour le May 7, 2024
10 - 20 minutes
Modérée
Use this guide to remove the LCD screen.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: étape 1, image 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: étape 1, image 2 de 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 2, image 1 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 2, image 2 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 2, image 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 3, image 1 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 3, image 2 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 3, image 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 4, image 1 de 1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: étape 5, image 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: étape 5, image 2 de 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 6, image 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 6, image 2 de 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 7, image 1 de 2 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 7, image 2 de 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 9, image 1 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 9, image 2 de 3 Disassembling Canon PowerShot SD1100 IS LCD screen: étape 9, image 3 de 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS LCD screen: étape 10, image 1 de 1
    • The LCD screen should now be removed.
3 autres ont terminé cette réparation.
Tyler Grossheim
Membre depuis le 01/25/11
1 524 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 3,724
