Aller au contenu principal
Disassembling Canon Powershot SD880 Menu Button
Ben Tupas
Ben Tupas et 4 autres contributeurs
Dernière mise à jour le January 28, 2014
5 minutes
Facile
Photos d’action
This may need to be removed if the button or scroll wheel is not working.
Ce dont vous avez besoin
Outils
  1. Disassembling Canon Powershot SD880 Menu Button, Back Cover: étape 1, image 1 de 3 Disassembling Canon Powershot SD880 Menu Button, Back Cover: étape 1, image 2 de 3 Disassembling Canon Powershot SD880 Menu Button, Back Cover: étape 1, image 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Menu Button, Menu Button: étape 2, image 1 de 3 Disassembling Canon Powershot SD880 Menu Button, Menu Button: étape 2, image 2 de 3 Disassembling Canon Powershot SD880 Menu Button, Menu Button: étape 2, image 3 de 3
    • Remove 2 screws from back of camera using screwdriver.
    • Remove 2 screws holding metal side guard using screwdriver.
    • Remove the connecting ribbon by pulling it straight out.
Ben Tupas
Membre depuis le 01/13/11
329 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,390
