Aller au contenu principal
Doov v15 Sim Card Replacement
Imani Williams
Imani Williams et 2 autres contributeurs
Dernière mise à jour le December 29, 2023
5 minutes
Facile
A besoin de meilleures images
A guide on how to replace a Sim Card inside of DoovV15 smartphone.
Make sure there's a sim card that matches up to the DoovV15 smartphone.
Work in a clean, well-lit area.
Use appropriate tools like a opening tool, and Jimmy.
Ensure you have the necessary safety gear to protect your eyes and hands.
Back up your data and power off the phone before you start. For additional help please use the step by step guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Doov v15 Sim Card Replacement, Sim Card: étape 1, image 1 de 1
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Sim Card Replacement: étape 2, image 1 de 2 Doov v15 Sim Card Replacement: étape 2, image 2 de 2
    • Use an Ifixit opening tool and slide it around the phones back cover. The Sim Card will be visible above the battery to the right.
  3. Doov v15 Sim Card Replacement: étape 3, image 1 de 2 Doov v15 Sim Card Replacement: étape 3, image 2 de 2
    • Disconnect the battery: Once the back casing is removed, the battery will be visible. Use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  4. Doov v15 Sim Card Replacement: étape 4, image 1 de 2 Doov v15 Sim Card Replacement: étape 4, image 2 de 2
    • Use the Ifixit opening tool and place it in the hole above the SIM card slot and push it downwards, so the SIM card slides downward. Place the iFixit opening tool on the now more visible SIM card and slide it down for an easy removal.
  5. Doov v15 Sim Card Replacement: étape 5, image 1 de 2 Doov v15 Sim Card Replacement: étape 5, image 2 de 2
    • Place the new SIM card in the slot by sliding it back in the slot, as shown in the figure (facing the sim number and code upward.)
Imani Williams
Membre depuis le 09/08/23
121 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 114
