Aller au contenu principal
Dyson Pure Cool AM11 Base Replacement
Gregory Crimmins
Gregory Crimmins et 4 autres contributeurs
Dernière mise à jour le April 29, 2024
5 minutes
Modérée
This Guide is to help you if you need to get access to the inside of your fan to fix wire the motor or other parts. We will walk you through the steps to safely open it up and put it back together.
Ce dont vous avez besoin
Outils
  1. Dyson Pure Cool AM11 Base Replacement, Base: étape 1, image 1 de 3 Dyson Pure Cool AM11 Base Replacement, Base: étape 1, image 2 de 3 Dyson Pure Cool AM11 Base Replacement, Base: étape 1, image 3 de 3
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Base Replacement: étape 2, image 1 de 3 Dyson Pure Cool AM11 Base Replacement: étape 2, image 2 de 3 Dyson Pure Cool AM11 Base Replacement: étape 2, image 3 de 3
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Base Replacement: étape 3, image 1 de 2 Dyson Pure Cool AM11 Base Replacement: étape 3, image 2 de 2
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Base Replacement: étape 4, image 1 de 3 Dyson Pure Cool AM11 Base Replacement: étape 4, image 2 de 3 Dyson Pure Cool AM11 Base Replacement: étape 4, image 3 de 3
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
Ligne d'arrivée
Gregory Crimmins
Membre depuis le 11/01/23
109 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 18
Total : 301
